blow by
   / blow by #1
sticky
Bronze Member
Northwest Indiana
While looking at older tractors, I hear the term no blow by. What does that mean and how can you tell if a tractor has blow by?
   / blow by #2
Do a compression check on each cylinder, high blowby is from worn leaky valve seals and/or piston rings.
   / blow by #3
Blow-by is a term used to describe compression ecsaping past the piston-ring-cyliner seal in the cylinder bore. There is always some compression escaping past the piston-ring-cylinder seal as it is impossible to obtain a 100% perfect seal in this area regardless of the engine condition. A compression test will evaluate each cylinder against any other cylinder or provide a comparison with know compression tables in a service manual. When blow-by is great enough there will be puffs of smoke and vapor emitted from the crankcase breather tube and perhaps also a milky whiteish deposit on the upper part of the dipstick tube and inside the valve cover. Leaky valve seals, either at the seats or the stems, do not contribute to blow-by. If you are unsure of your ability to make a determination and you are including this criteria in a purchase decision, you should consult a professional, which I am definitely not.
Best of luck,
Martin
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A53473)
2018 Link-Belt LBX...
2014 Triple Crown 10ft S/A Utility Trailer (A51694)
2014 Triple Crown...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51691)
2001 Dodge Ram...
Bad Boy Pro Z Zero Turn Mower (A53117)
Bad Boy Pro Z Zero...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
