"Blow by" question
   / "Blow by" question #1
bludev
Central North Carolina
Mahindra 6500 2wd
Can someone explain to me how to reliably check for "blow by" on a Kubota V1702 ... its in a Bobcat that is getting harder and harder to start when cold. It doesn't seem to be using oil but I have taken the oil filler plug out while it was running and did feel air coming from there in sync with combustion cycles ... there was no smoke or other film noticed with the air being pulsed out of the oil feel plug ....
Thanks for any input
   / "Blow by" question #2
Dont mean to sound smart at all, but the best and most reliable thing to do would be a compression check. Way many moons ago when the B series Cummins were first coming out they did have an apparatus to hook up to the blow-by tube to measure it, imagine same theory would work on Kubota. It's just telling you what you already know. Compression check figures would be more valuable.
   / "Blow by" question #3
More than likely what you are feelling are the pulses cause by the returning pistons into the crankcase if there is no smoke . Does it have glow plugs ? Maybe a couple have given up . Does it have an intake heater ? I seem to find also that winter Diesel takes a bit more effort to fire up .
   / "Blow by" question #4
You really want to make sure your entire glow plug system is working properly. That engine seems to need more time on the glow plugs at a given temp than say a 2203 and the more hours it has the more it needs it. There's a glow plug/relay solenoid (743?) in the tailgate. And the glow plugs themselves just wear out after a while.
Thanks guys ... I think I'll change the glow plugs .... the guy that had it before me said he didn't think it had glow plugs, so I'm sure he never changed them. If that doesn't fix it, then I'll do the compression check ...
thanks all and if anyone has input I'd be glad to hear it
   / "Blow by" question #6
Just for information the Kubota B7100 I had always had significant vapours coming from the crankcase even when new. It was also quite hard to start unless it was warm. The glow plugs were required.
The engine did not use any oil even after 3000 hours of operation which is not much in industrial situations.:D
   / "Blow by" question #7
Test or change glow plugs and check for power right at the glow plug when activated. Could be a bad relay not supplying juice, test injectors, test compession.
Consider installing a block heater if the motor is getting tired and needs some help to get the last 500 or so hours out of it.
Ken
   / "Blow by" question #8
Glow plugs, glow plug controller, relay, fuse, wires, key switch.
There does not sound to be blow by. If you had that, it would have a LOT of gases coming out the filler plug hole. Smokey blue fumes.
   / "Blow by" question #9
Is this in a 743?
Before you start changing anything, a little time with a meter, or for that matter a test light will go a long way.
Make sure you are getting full power too the glow plugs first so you know which side to start looking.
The glow plug closest to the back of the machine is a bugger to do.
   / "Blow by" question #10
Bluedev, Just to add a little more, I have a kubota b7100 which emits a lot of vapour from the crankcase tube. I did quite a lot of internet researching to find that crankcase pressure can result in quite a lot of vapour coming from that tube. In winter the cold weather will make the problem look worse.
I thought I had problems until I did a compression test which proved all of my rings were above average and giving a good seal in the cylinders. I also checked for headgasket problems and other signs of concern but could find none worthy of corrective action. I've learned to live with the vapour. To reduce the visual effect of the "blowby" on my b7100, I fitted a crankcase filter to the tube which dissipates the fumes without restricting the airflow. It also lessens the effect of the fumes jetting out of the end of the tube.
Heres a filter similar to the one I have :-
I dont see the "blowby" as a problem unless as stated above, it is emitting blue smokey fumes.
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2025 Star EV Capella Electric Cart (A51694)
2025 Star EV...
2025 Swict 66in Bucket Skid Steer Attachment (A51691)
2025 Swict 66in...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
