Blow by Blow water pump change out???
   / Blow by Blow water pump change out??? #1
BobG_in_VA
Veteran Member
Central VA, USA
Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
I'm going to change out the the waterpump on my '67 MF135 (Cont. Z145 engine) in the near future. Anyone out there done this and any information on "do this..." or "don't do that..." would be appreciated. I'm gonna pick up pump/pulley already pressed together so I don't have to do that...I'm pretty sure I've got to pull the radiator, etc. but any info is appreciated...BobG in VA
   / Blow by Blow water pump change out??? #2
Sounds like you've got the hardest part of the job licked, most of my time was spent convincing the pulley off the pump shaft. As you state, pull the fan and radiator and there is plenty of room. I did use an appropriate sealant along with the gasket provided with the new pump just to be sure I wouldn't be pulling it apart again. I also took the time to clean and lubricate throttle linkages etc that are much more accessible with everything out of the way. Good luck.
New Long Forks (A53002)
New Long Forks...
2013 Mack GU813 Roll Off Truck, VIN # 1M2AX13C1DM019680 (A51572)
2013 Mack GU813...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
8ft x 6ft Container with Side Door (A51573)
8ft x 6ft...
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
