Block heaters ...
   / Block heaters ... #1
Madman_Mark
My Fiat won't start unless it's plugged in even when the temp is above freezing (around 5 celcius and lower).
This is my first tractor but I thought starting in the cold wasn't a problem until it was really cold out.
I guess some are different then others.
   / Block heaters ... #2
i would think that any tractor or any vehicle for that matter would not have a problem starting at those temps. my tractor starts right up no matter what the temp, a few sec. on the glo plugs and she fires right up. no heater on it.
   / Block heaters ... #3
My old Chinese Bison was a bear starting in cold weather. I never had a block heater on it but I did have to fire the glow plugs for extended periods in real cold temperatures as well as use the compression release to get it spinning quickly. I haven't had my New Holland long enough to know if there will be a problem there or not.
   / Block heaters ...
This one doesn't have glow plugs.
It has a "thermostarter" which I haven't quite figured out yet, or it doesn't work.
   / Block heaters ... #5
Never heard of a diesel without a glow plug but then I never heard of a thermostarter either. I'll be watching this thread to find out for myself what it's all about. Hoping someone else will jump in here with more info on the subject.
   / Block heaters ... #6
The Cumins diesel in Dodge trucks does not have glow plugs. It uses an air preheater and fuel heater.
Egon
   / Block heaters ... #7
Thermostarter fuel burner in intake manifold for easy cold starting.
This is what I found on the internet about thermostarters. Once I found this I do remember hearing about them. If I remember right there was a fuel used to heat the intake manifold but not sure.
murph
   / Block heaters ... #8
Check out this recent discussion about the thermostart system on a Yanmar tractor, you may have something similar.
   / Block heaters ... #9
Mike,
My John Deere 850 has thermostart
This is from my owners manual
Thermostart Device
An electric glow plug ignites a small amout of fuel in the intake manifold
   / Block heaters ... #10
The thermostart system has been around for some time. My dad's David Brown 990 has this system and it is a 1974 or there abouts. It works well down to about 15. Below that she wants plugged in. Badly.
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
1990 International 8300 Vacuum Truck (A47384)
1990 International...
Case IH 3408 8 Row Corn Head (A52349)
Case IH 3408 8 Row...
2009 Ford F250 Super Duty (A50515)
2009 Ford F250...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
