roxynoodle
Veteran Member
Is anyone using any type of block or radiator hose heater on their Yanmars? I'm not certain but my tractor does appear to have at least one freeze plug. A radiator hose heater may not fit on it. I have considered a magnetic heater for the oil pan but I'm not sure it would be effective when temps get to 10 or below? Or, would the best option be to use a high powered space heater and cover the tractor with something like a fire resistant blanket to help it get started in really cold temps? Or should I just say oh well, it's too cold, better not use the tractor? I haven't figured out yet just how cold it has to get for it not to start. Maybe it's just fine the way it is and I don't need a heater of any kind
I'm interested in hearing any of your opinions or what you do to aid cold weather starting. So far the tractor has started on the first try every time. I put in a cold weather diesel additive and all fluids and filters were changed this summer and are in good condition. I did put in 15w40 diesel oil. Should I change that to a lighter grade for winter?
