Block heater
   / Block heater #1
bones66
Bronze Member
BlueGrass State
MF-230
I recently installed a new engine block heater. The new heater was a different brand than the old one. My old one had served me well (over 40 years) and decided to call it quits. Although I don稚 use it that often. When I installed the new heater which was a different brand I flushed and changed the antifreeze draining the block and radiator. When I plugged it in I noticed the familiar sound like a steam iron heating up. Later I went back and the thing was making a humming/squeaking sound. Kind of like shutting the water off an outside water hose. My first thought was maybe cavitation in the block however I had drove the tractor over and hour out to a barn and return 2 times. I plugged it in again and it started that humming/squeaking immediately. It seems to heat ok or as much as I can tell by touch.
   / Block heater #2
Electric water heaters make the same sound at times. The block heater on my Kubota does too but much more subtle. I wouldn't lose any sleep over it.
   / Block heater
Thanks mcfarmall, actually I had decided to just do what you said. Last time I plugged it in it sounded just like the old one.
You said not to lose any sleep over it reminds me of what I used to tell my kids. This advertisement has stayed on my mind for years and it’s actually saved me a lot of grief.
Dry Idea Tim McCarver Deodorant commercial - 1988 - YouTube
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
