BLOCK HEATER
   / BLOCK HEATER #1
alvanko
Hinckley , Ohio
Yanmar YM186D & Ford LGT14D Dixon Z BX2200D Kubota
Does anyone here know if a block heater was ever offered for the D1101A 3 cylinder engine used in the L245/L2201 ? If so , where is it available from ? I have compression release and glo-plugs , but heated engine would also help in the winter and would help prolong engine life too by slightly heating the block/oil . Winter is approaching quick !!!
   / BLOCK HEATER #2
I don't know about that specific engine but I can't believe that there isn't one available. My F2400 has one and I would think the engines are very similar.
   / BLOCK HEATER
Where is it mounted ? In a freeze plug hole ? In a threaded hole some where ? In the block or in the head ? Dimention ? Diamater ? Factory or after market ?
   / BLOCK HEATER #4
It's mounted in the side of the block to the front of the starter motor. I am reasonably sure it is threaded. I don't know if it factory or not. I will have a close look in the morning and try to give you more details.
   / BLOCK HEATER #5
I had a look. I thought of taking a picture but you wouldn't see much. It is threaded - quite large, possibly 26 - 28 mm. It is between the starter motor and the oil pressure sender switch. I have no idea if it is original equipment, but it looks like it could be. I keep my tractor inside dduring hte witer so I have never used it and don't know if it works. I may try it this later this far out of curiosity.
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2013 Kubota F2680 (A50123)
2013 Kubota F2680...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
197711 (A51244)
197711 (A51244)
2025 CFG Industrial QK18R (A50123)
2025 CFG...
