Block heater location?
   / Block heater location? #1
buzst
south NH
Kubota B2150HSD
I just bought a kubota block heater part #70000-73274 for my b2150. The install instructions say to unthread a plug in the engine block with a 17mm allen wrench and replace with the heater. Sounds like it should be a simple install but I can not find where on the engine the threaded plug is located. My dealer didn't know either. Does anyone know where this should go?
Thanks...
   / Block heater location? #2
Sitting in the drivers seat of my B2410, the block heater is on the underside of the tractor on the front left, just back of the exhaust.
Kevin
   / Block heater location? #3
I have a B2910 and it's just back from the oil filter in the side of the block.
Regards,
Chris
   / Block heater location? #4
<font color=blue> I can not find where on the engine the threaded plug is located. My dealer didn't know either.</font color=blue>
And he can't find out???? This seems incomprehensible to me!
This ain't brain surgery. Can't he just call the factory and find out how to install it? Has he never had a customer who wants a block heater before? I would say call him and tell him to find out.
Chris,
Thanks, I would think that because we both have V series 4 cyl. engines the heaters would be in the same location. On my machine after the oil filter is, the dip stick, three freeze plugs, then the oil presure sensor. Is your heater is installed in place of a freeze plug or in a boss on the block?
Thanks...
Thanks all, the dealer came thru. The heater is installed on the right side of the engine, under the fuel pump. There are two hoses that return to the engine from the bottom of the radiator. The solution is to cut the smaller of the hoses and plug it where it exits the radiator. Then remove the plug the other half of the hose attaches to, from the engine block and replace with the heater. I'm not sure I like the idea of having a plugged hose dangeling from the bottom of my radiator. What do you guys think?
   / Block heater location? #7
Sure doesn't sound right to me either. My block heater is installed directly in the block of the engine. There was a threaded plug in the side, under the exhaust manifold that I unscrewed and screwed in the block heater. Just that easy. The tough part was that the plug required a 17mm Hex wrench that I had to buy at sears....something I'll prob never need again, ya know?
Anyhow, there were no hoses to cut or plug. Seems my engine was set up for this. I don't think I'd want to do any of that...seems like there would be a reason for 2 hoses to be there in the first place....
   / Block heater location? #8
This does not sound right to me. On my 2710 there is a threaded bolt (17MM) just under the thermostat. I just removed that bolt and the block heater installed into that threaded hole. Are there any install instructions with it. This does not sound right to me. You should not have to cut a hose and plug it. is it then supposed to go into the engine block or into the end of the hose that is now unplugged?
   / Block heater location? #9
Hey! guys ......can someone snap a pix and share with us the mysterious location /w3tcompact/icons/hmm.gif /w3tcompact/icons/grin.gif of this 17mm allen nut that accepts the block heater? ...Thanks, RayBee /w3tcompact/icons/smile.gif
They say to cut the hose at the radiator and plug it. Then remove the plug (see photo) and replace with the heater. The hose never gets reattached. I almost think I would rather not have a block heater, than run the risk of dumping all the coolant should the pluged hose blow....
John Deere PT Land Leveler (A50123)
John Deere PT Land...
44029 (A51692)
44029 (A51692)
CONTAINMENT SKID MOUNTED (A53843)
CONTAINMENT SKID...
72'' skid steer bucket (A53421)
72'' skid steer...
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
