block heater for JD 2720
   / block heater for JD 2720 #1
logankelly
Bronze Member
winona mn
jd2520
Do I have to go to a JD dealer to get a block heater?
   / block heater for JD 2720 #2
Probably not. With help from Mechanos here I found a Zero Start block heater for my 955 on the web. The Zero Start catalog/applications guid is here:
Phillips & Temro - Catalogs
Find the tractor or engine you have then search the web for the Zero Start part number. There are lots of resellers of the Zero Start block heaters.
Like others, I subscribe to the notion the JD resells the Zero Start product in a $50 John Deere box.
   / block heater for JD 2720 #3
Have you looked at the one John Deere offers for the 2720? It is P/N AR87167 and sells for around $75. It looks fairly easy to install.
   / block heater for JD 2720 #4
The JD heater is way easy to install. Pop out the freeze plug and bolt it in.
   / block heater for JD 2720 #5
Zerostart - Engine Heater
Part # 3100003 :thumbsup: at O'reilly's
   / block heater for JD 2720 #6
That's not bad... I found it for $26 online, but by the time you add on $6 or $7 for shipping it's right around the price at O'Reilly's. Of course, I did save the sales tax too.
It is exactly the same part you'd get from JD... right down to the color of the cord connector. But you will have to learn to live without that fancy $50 JD box.
2004 Ford F-250 4x4 Crew Cab Mechanic Service Truck (A49461)
2004 Ford F-250...
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
2006 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2006 STERLING...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
