Block drain plug left side of engine is a puzzle
   / Block drain plug left side of engine is a puzzle #1
ampa
I'm wondering why this drain plug has a hose running from it, looks like a 1/4" braided hose much like the fuel lines, runs from the plug to a spigot on the bottom of the rad tank, this is an ISEKI 17 hp 3 cyl. diesel (G-174) I'm wishing to use this as a return from a circlating block heater I,m tryin' to install, the manual states nothing except that this plug is a block drain on the left side of the engine block if it has a purpose other than just a way of draining the cyl. block, if not I may have to install a "Y"connection and keeping it original, or can I just cap off the spigot on the lower rad tank, and use it only as a return to the cyl. block for my block heater....Thanks AMPA:confused:
All I need to know does this hose have a purpose, ? bein' connected from the block to the bottom rad tank Thanks AMPA
recieved no comments, so I gather I can plug the bottom rad 1/4 nipple and do way of it, .....Thanks Ampa:D
   / Block drain plug left side of engine is a puzzle #4
it is their to drain the block when you drain the radeator
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
2008 FORD F-350 (A52472)
2008 FORD F-350...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
