Bleeding, wet breaks.
   / Bleeding, wet breaks. #1
DJM Solutions
Clark forklift
Working on a fork lift. Clark GCS 25MC. Has what they call wet brakes ,clutches inside Transmission fluid Don't know much about. Machine has sat for a long time. Somebody installed new master cylinder. I'm just starting on it. pull fluid with vacuum pump At bleeders topping off master . Calendar at the same time. Looked over all lines, all looks to be correct.
   / Bleeding, wet breaks. #2
And?
The hydraulic system is the same whether wet or dry brakes. Wet brakes are just discs running in the same oil as the axle. They are more durable than dry brakes.
Some systems use a piston in the axle that is the diameter of the brake discs themselves. If they are this type, you probably should be using mineral oil brake oil rather than brake fluid.
200387 (A51247)
200387 (A51247)
2012 FREIGHTLINER DURASTAR 4300 M7 SBA 4X2 BUCKET TRUCK (A51406)
2012 FREIGHTLINER...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
Unused Delta Crash...
2018 John Deere 460E Articulated Dump Truck (A55218)
2018 John Deere...
