Bleeding wet brakes?
   / Bleeding wet brakes? #1
Michael Ides
I have a Yanmar grey market tractor, FX28D. It has wet internal brakes. I lost the reservoir line into the brake valve and so the brakes are not functional. I replaced and refilled the line but no brakes, I am assuming that I have air in the line. I am not finding a place to bleed the lines, any suggestions? I have a catalog which shows the parts but I dont see anyplace to bleed. I also have a catalog for a John Deere 336 which is supposed to be similar, but it has external dry brakes- so no help there. Any advice?
   / Bleeding wet brakes? #2
So you are saying the brakes are not a mechanically connected, but have a master cylinder like car brakes, with brake fluid under pressure in a brake line?
If so, there should be a way to at least crack the brake line between the master cylinder and the brake cylinder, which mechanically activates the brake shoes.
Something just doesn't sound right to me here. :confused:
   / Bleeding wet brakes? #3
I know nothing about a Yanmar. I had a 574 IH and the bleeders were on each side of the axle housing under the rockshafts. They were larger than what's on a car or truck. They were a little hard to get to but could get my hand in there to do the job. Bled them just like a car but the tractor engine running needed to be running on that model. Had to have someone in the seat to press the pedals too.
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2005 GEHL CTL70 TURBO SKID STEER (A51242)
2005 GEHL CTL70...
BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51242)
BOMAG BW172D-2...
2007 GMC Acadia SUV (A50324)
2007 GMC Acadia...
