Oil & Fuel Bleeding Fuel System
   / Bleeding Fuel System #1
Prodirt6000
Bronze Member
I've got a LS 170 Skid Steer
We changed the fuel filter today, inline, and the fuel water separator one. When it was put back in, we didnt put fuel in the fuel water filter before installing. Engine did run for a while, but then stalled out...
Went to bleed the lines and on this injection pump there is no bleed screw. We found that there is fuel getting to the injection pump. Cracked the lines in the injectors and we got it running.
Then it stalled out again after running for a while. Tryed doing the same thing, but now there is no fuel getting to the injectors. There is fuel getting to the injection pump, but not going thru it.
We turned it over and over and over and one time fuel did start to shoot out of the injector. But we had it cranked over so long, that we thought we would burn up the starter.
So my question is, why is there no fuel getting thru the injection pump now? Should I let the fuel pump run for 10 min or so with the key on...I would be thinking that maybe it will build enough pressure in the injection pump so that when we crank it over, the air will want to come out quick.
Any Ideas??
Thanks.
Oh and all the fuses are good.
2014 Mercedes-Benz Sprinter 2500 Ambulance (A51692)
2014 Mercedes-Benz...
Multiquip GA9.7HEA 9700W Generator (A51691)
Multiquip GA9.7HEA...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2011 John Deere 3038E (A50123)
2011 John Deere...
2017 Bobcat E20 Excavator (A52384)
2017 Bobcat E20...
