Bleeding Fuel Line
   / Bleeding Fuel Line #1
spindlewood
Bronze Member
Northern Idaho
Kioti DK40SE HST Cab
I've got a DK40se and when I replaced my fuel filter, I stupidly forget to unscrew the bleeding bolt when cranking in the ON position. I presume the tractor won't start because there is fuel in the injector lines. I was able to access one of the injector nuts with a regular wrench and got a bit of gas to run out (not sure how much I should bleed). The others look like they need a 90 degree wrench to open. I want to make sure I'm going down the right path to get it started before I buy tools and go through the process.
The manual is a bit obtuse with regard to how many injector nuts to bleed and which end of the line to unscrew. I unscrewed the nut up top above the engine block. What a pain. Any guidance would be appreciated.
   / Bleeding Fuel Line #2
How long has you run it on the starter? Sometimes you have to crank it for a long time to get it to start.
Hard to quantify. Probably 8 times of 10 cranks. After leaving the tractor alone for an hour, I came back and finally was able to loosen 2 injector nuts with a straight wrench. Whether it was the wait or having 2 loose, it started up quickly (albeit roughly and spraying gas everywhere). Tightened it all back up and good to go. Made my filter changes into a longer day than I had hoped but got 5 filters swapped out and changed the engine oil. Feels good. I'm at 225 hrs, so a bit behind schedule
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
Quick Attach EZ Axe Skid Steer Tree Shear (A52748)
Quick Attach EZ...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52748)
Michelin CARGOXBIB...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
