Bleeding a cylinder.....
   / Bleeding a cylinder..... #1
Frankdozer
Bridgton, Maine
1967 Case 580CK Backhoe / Loader
On my 1984 John Deere 455D bulldozer with 4 in 1 bucket, I had a leaky hose in the right hand bucket cylinder to control valve line. This is the 3/4" hose that makes the bucket curl up and down. When I disconnected the old hose about 2 gallons of fluid came out from the control valve side of the line. I think it also drained out the lines on the left side since the left side " Tees " off the right side. I decided to replace both hoses on the right side going from the bucket cylinder to the control valve stopping short of where the left side " Tees " off. I had both 3/4" hoses made at the local NAPA store. They do nice work and are very helpful. Well, I connected up everything and now the bucket doesn't want to curl. When it leaked, it curled perfectly. What do I need to do now? Bleed it, if so,how, there is no bleeder bolt. Thanks, Frank.
   / Bleeding a cylinder..... #2
Activate the lever until the relief goes on. Cycle the cyl about 5 times through a complete cycle holding the lever until the relief goes off each time.
That should purgr all the air out of the cyl.
Well I found the problem.........................I unknowingly crossed the hoses...................... I connected the hoses the correct way, cycled it 5 times as J_J said to do and now it works as it should. No leaks
Thanks, Frank.
2017 HITACHI ZX350LC EXCAVATOR (A54607)
2017 HITACHI...
2020 Golf club car (A53424)
2020 Golf club car...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2004 FREIGHTLINER COLUMBIA (A53843)
2004 FREIGHTLINER...
JOHN DEERE 850K WLT CRAWLER DOZER (A52705)
JOHN DEERE 850K...
