bleeding 1990 Ford 445C fuel pump
   / bleeding 1990 Ford 445C fuel pump #1
Burlick
1990 Ford 445C
I'm having a hard time bleeding the fuel pump. I'm getting and bleeding fuel into the filters ok but not into the fuel pump thus none through the injector lines. We're getting a slight drip of fuel from the bottom of the pump and am wondering if that is creating an air gap. The tractor was running fine before we had the steering motor valve rebuilt and replaced but now it won't start. Any suggestions how to bleed fuel system properly. It's gravity fed.
   / bleeding 1990 Ford 445C fuel pump #2
I would open the line between the filter and the injector pump (IP) and check for adequate fuel flow there. You should get a CONTINUOUS gush of fuel at that point. If it dribbles or is intermittent, you have a restriction of some sort between the tank outlet and that point. Work back to the tank to find it. It could be a pinched fuel line, crud at the tank outlet strainer, in the filter head passages, the fuel filter itself, etc.
If you do get a continuous gush of fuel, open the bleeder on the IP and open the throttle, then crank the engine until you have fuel squirting out of the bleeder hole. Make sure it's bubble free and then close it and try to start. If it doesn't start, bleed the injectors by opening the connection at the injector until you see bubble free fuel and then tighten. Usually by the time you get to bleeding the second injector it will start if the IP is OK.
50ft Fuel Line (A51573)
50ft Fuel Line...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
JOHN DEERE 4730 LOT NUMBER 274 (A53084)
JOHN DEERE 4730...
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
