Blades will not disengage...
   / Blades will not disengage... #1
weedchopper
Hello All,
I have a Cub Cadet 127
S/N 2050040U311013
Kohler K301A 12HP
Mower Deck 421U1113
The mower blades will not turn off once tractor is started. This also makes for a hard start because of the blades turning when I turn it over. Mower lever (on the left) is not working.
Is it:
1. PTO Clutch (IH kit IH 759-3490 along with PTO bearing IH-60071-C92)?
2. The mower drive pulley (wobbles a bit). Spindle bearing maybe? (473430R91)? If it is this, do I need the bearing seal also(473428R91)?
3. Is it something else?
4. all of the above?
Could you please point me in the right direction for info via links. Any information is greatly appereciated. Thank you for your time.
weedchopper
   / Blades will not disengage... #2
PTO clutch stuck or PTO electric solinoid defective
Thanks dqdave1! I will have to look into those two things.:cool:
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51694)
2018 Suzuki...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
UNUSED White Metal Roof Panels (A53117)
UNUSED White Metal...
2012 Subaru Legacy Sedan (A51694)
2012 Subaru Legacy...
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
