Tejas
Bronze Member
Folks, I need help understanding and calculating blade tip speeds for rotary cutters/shredders. I assume there my be an actual formula of sorts floating around??
I have converted a Bradco SSL 72" cutter that originally had a hi-flow hydraulic motor attached to a RC-71 gearbox. Some of you helped me to figure out what I needed to get that job done via another thread. I ended up using a 9.59 CID motor. This, powered by a 19GPM SSL comes out to 458RPM....seems a bit slow but I wanted the higher torque. I know there is a missing number here, the gear ratio of the gear box...The deal is, I contacted Bradco and they sent me the specs on two of their gear boxes, a RC-51 and RC-61, both of these have a 1:1.93 ratio. I Will send another email to Bradco in attempts to clarify what the RC-71 has for a ratio.
Some questions:
- Are all shredders running the same Blade Tip Speed, or even close? As in, does a 5', 6', 7' shredder all run the same speeds? Understanding the longer or shorter the radius will effect the final speeds...does this get compensated for with a different gear box ratio or by controlling the speed of the motor/PTO turning it?
- What is the real limiting factor on maximum blade speeds?
- What is an average gear box ratio for a normal 3-point/PTO driven gear box?
I am preparing to build a 5' brush cutter for a neighbors 15GPM Bobcat. I really want to ensure I get everything correct. I appreciate all the help!
Some questions:
