Grading blade for 2500 series and hood problems
   / blade for 2500 series and hood problems #1
kgkx125@hotmail.com
I own a 2005 lt1046. I'm thinking of selling the unit for a 2500 shaft driven model. Purpose for new unit would be mowing and light leveling of loose dirt for leveling of the yard with the optional blade for these units. Can anyone tell me if they have had experience with the 2500 series and blade for light duty dirt leveling and other tasks such as the hydraulic tiller. Also can anyone tell me if the hood melting on the 2500 series has been resolved and also how far back in models does this problem go.
   / blade for 2500 series and hood problems #2
I have a '06 2544 with the dozer blade. I've "plowed" over honeysuckle, move small dead tree trunks (about 6" diameter and 10-20' long, and used it to spread and level gravel and dirt. The blade is very heavy duty, which is why it costs more than 2X the snow blade for the 1000's and 1500's.
I never experienced any hood problems. But my dealer did replace the entire hood when I took it in for it's first scheduled maintenance last December. He said he did it because Cub had issued a TSB or recall on the hood latch. I wasn't having the problem but he figured that the tractor was in the shop, I wasn't in a rush to get it back, and Cub was paying the bill, so why not?
I've only talked to two people personally that own 2500's, and they too never experienced a hood issue. But they bought from my dealer as well, so it's possible that the dealer dealt with the problem before delivering the tractors.
As for the people here that have had the problem, there were some variations on what actually went wrong:
The first issue was a latch failure. This occured slowly and would cause the hood's "closed" position to creep higher and higher. This would eventually lead to the exhaust being partially blocked, and thus melting that portion of the hood. This was resolved by Cub back in late summer/early fall of '06 with a redesigned latch, and a TSB was issued.
The second issue was heat under the hood. Someone took the time to measure temps at various locations and compare them to what Kohler recommends for their engines. His reading were higher than what Kohler told him they should be. I also took temps and got results that were a fair bit lower than his. Best guess is that this excess heat issue was really only a problem on the 2550's and 2554's, probably because the decks were much larger and put much more of a load on the engine. But in any case, Cub has put out at least 2 updates to the heat shields for all 2500's. When I bought mine in June of '06, it came with what appeared to be the final variant of this heat shield. But others have reported purchasing tractors much later than me, and getting them with an earlier heat shield configuration. I have no idea why this is the case, unless my dealer put on an updated heat shield when it was in for service last December, and I just didn't notice. What I can tell you is that I've had no issues with heat, but then I don't mow when the outside temp is over 80d anyway. I also removed the center louver cover as a precaution.
The third issue was with the strut mounts on the hood being cracked due to overtightening at the factory. This was resolved by most dealers by simply replacing the hood and installing them correctly. Cub at some point figured out why this was happening at the factory and corrected it there. I can't tell what time period this happened in because there's no easy way to know how long the tractors were sitting before this problem was noticed. My dealer never had any on his floor that had this problem, but then he's really good at going over the tractor's before delivering them or putting them on the floor.
So, in summary, the hood problems go back to all '06's models, and have been resolved. I don't know whether all '07's included all updates or not. I'm sure all '08's do though.
   / blade for 2500 series and hood problems #3
I have a 2003 2518. It is the very first model of the 2500 series. It is the same as a 2544. I think the only difference is I have a 20 hp in mine. I couldn't be more pleased with it. My unit has the metal hood so I don't have the melting hood issues.
I don't have a Dozer Blade yet but I have checked them out and they are very heavy duty. My dealer spoke highly of it. I just can't afford one right now.
As far as mowing it does a great job. I have the ag tires so traction is superb.
Hope this helps in your decision!
Michael
   / blade for 2500 series and hood problems #4
* Also can anyone tell me if the hood melting on the 2500 series has been resolved and also how far back in models does this problem go.
I have a 2554 with 54'' mower deck, tiller and front blade that I bought new back in Sept. of 2006.
Tractor only has about 81 hours on it.
The tiller and blade have never been used as I've never had them on the tractor.
It's a great outfit - No complaints whatsoever.
*I've never had this issue with it.
I wanted something with four wheel drive,power steering,hydraulic lift,rear PTO,3 point hitch and a diesel engine so I bought a Kubota BX1500 with a front blade and a rear tiller when a deal came along that I just couldn't pass up.
== L B ==:)
   / blade for 2500 series and hood problems #5
I use a tiller to create the loose dirt to move with the blade.
   / blade for 2500 series and hood problems #6
What's your location?
   / blade for 2500 series and hood problems #7
kgkx, I purchased a 2554 in Sept. of '07, I had the broken hood mounts, dealer I have in Lafayette, la., is Exemplary. Congress outdoor, Man is Chris Saucier. He's THE MAN. I love my Cub. I cut the grass twice a week, we get a lot of rain and grow a lot of grass. I keep up 2 acres, I haven't had the melting issues, it has 30 hours, and it is a MULE. Yes my dealer took care of the hood issue, and the Kohler had a small leak at the oil drain valve, it wasn't tightened. I've no problems with this tractor nor dealer. I would buy another one, I thoroughly enjoy doing my yard work. My only gripe would be a larger fuel tank. Well, at least it's made over here, at least I think so. Who knows anymore. :p ps, the stock blades have held up tremendously well. Now you have to remember, I was used to those little 1000 dollar Murray and mtd tractors. Briggs has put a bad taste in my mouth. 2 acres is just too much for those inexpensive units. PS, I wish it had air conditioning. :D
   / blade for 2500 series and hood problems #8
FYI; your 2554 is an MTD.
   / blade for 2500 series and hood problems #10
I agree; but it is STILL an MTD built in Cleveland , Ohio
Wolverine Quick Attach Manure Bucket (A50515)
Wolverine Quick...
2006 Pearson Quantum Hale Pumper Fire Truck (A50323)
2006 Pearson...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2020 John Deere 260E Off-Road Dump Truck (A50322)
2020 John Deere...
2005 International 7400 Cattle Truck (RUNS)(TITLE) (A50774)
2005 International...
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
