Blade Change Fail
   / Blade Change Fail #1
JDGreenGrass
Veteran Member
Maine
John Deere 770
I have a Craftsmen rideing mower with a 42" deck. While removing the blades one of the bolts came out hard....real hard. The bolt must have gone in cross threaded.?? Anyways, I did get the bolt out but both, the bolt and the threads on the mower are stripped.?? !@#$%$#@!!!!!!
I have never "tapped" anything. Is it possible to tap the stripped threads and buy a new bolt to replace the old.??
   / Blade Change Fail #2
is the blade attached to a spindle? couldn't you just replace the spindle?
   / Blade Change Fail #3
You might try a heli-coil kit to replace the threads.
   / Blade Change Fail
What is a heli-coil kit.?? And, where do I purchase if that's what I need.??
Randy.....Is the spindle the shaft that the belt's "fly-wheel" is attached to.?? If so, I think that part is held in place with 4 bolts.
I'm beginning to think the whole deck will have to come off.
I'll do about anything to NOT have to deal with Sears.
   / Blade Change Fail #5
I'd start by trying to rethread the existing hole. Barring that, drill it out to the next size up and tap it out there.
   / Blade Change Fail
Right. This is what I want to do.
Thing is, I don't have the tools. Will a local hardware store have what I need.?? If not, where to purchase.??
It's a tap set that I need, correct.??
   / Blade Change Fail #7
the spindle attaches to the belt and has 4 bolts holding it to the deck. this is the more expensive fix, so if you are looking to save money try the other suggestions first.
   / Blade Change Fail #8
A heli-coil kit is a kit that you can get at most auto parts stores and comes with a drill bit and a tap and steel coil so you can replace the threads..
   / Blade Change Fail #9
Your best bet is to take the spindle off and see what would be the best option.
You are not going to drill / tap or helicoil it very easy with it still attached.
If there is a lot of hours on it you might at least price a spindle but the helicoil would probably cheapest and easiest.
Just make sure you do it right. You don't want a blade coming off while under power. If you don't think you can do the correct fix, get a new spindle.
   / Blade Change Fail
All great advice. Thanks.
I fixed the problem by taking the spindle off the deck and then tapped new threads into the shaft of the spindle. It went quite well once I figured out ya gotta put a little muscle into it. Getting the spindle off was simple enough with just 4 bolts. The thing with the spindle is you got to have a wrench on both ends. The Craftsmen provided ample working space. Simple.
Hey, I mowed the lawn tonight. Lawn looks great with 2 new blades on the mower. Not to mention the new threads.!!:thumbsup:
As to how did that bolt get twisted??.... I know when I changed that balde last Spring that bolt went in fine....I think I know what happened. I hit a big rock. Probably several. This is my 3rd year here and the yard has settled. I have had a lot of 3 inch rock pocking through the lawn. The good news is, I got a John Deere to cover up that little problem.
Let the fun begin.!!:D
40ft Sea Container (A52384)
40ft Sea Container...
12in x 16.5in Kubota RTV-X1140 Tires (A52377)
12in x 16.5in...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
Informational Lot - Financing (A55302)
Informational Lot...
