Snow Blade Angle Piston
   / Blade Angle Piston #1
RProv
North Franklin, CT
Bolens G194/Iseki TS1910F
I have a Bolens G194/TS19104 with a 60" plow blade. It is missing the R/L angle piston. Can I use one double action cylinder as well as two single action
ones?
I know the OEM aren't avaiable but with proper dimensions I won't have a problem finding a suitable piston.
Does anyone have the bore, stroke, diameter, overall length, rod diameter, etc? I can deduce the end pin size from the mounting points.
Thank you
Rich
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
8'x8' Aluminum Cover (LOCAL TOWNSHIP) (A50774)
8'x8' Aluminum...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
TRUCKING INFO (A50774)
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
