Black Widow deterrent
/ Black Widow deterrent #1
KTurner
This is the second time I've opened the well house lid to find a black widow. The well house is cinder block, about 3'x3'x3', with most of it below ground level and a wood/metal lid that stays in place unless its being worked on. This time, the black widow ran right under the pressure switch, which is exactly what I wanted to look at (the well is cutting off). The other time it was underneath the lid.
Any recommendations for a product/home remedy for keeping these things out of small areas such as this well house? I haven't noticed them anywhere else (but I *really* doubt there's only one or two around).
Keith
/ Black Widow deterrent #2
You described exactly the kind of place (dark, undisturbed typically) where black widows love to be.
In my experience, if you are somewhat watchful when going into such places, you can easily see them and avoid/kill them. I've never seen one be aggressive and try to come after a person.
Net... they are are a part of country living... I learned a long time ago to look carefully before just sticking my hand under and into a black hole. I doubt that there is anything that would be effective and acceptable as a deterrent.
/ Black Widow deterrent #3
If you want to spray a spider you see, regular insect spray doesn't work well on spiders. However, wasp & hornet spray does work and works well.
/ Black Widow deterrent #4
Keith
May I ask what state you are in? You just described my well house. A friend from Kentucky called it a Kentucky well house, although I am in NC. He says it will not freeze, and for 20 years now, it has not.
As for the spiders...I found them in my firewood this winter. I found one the other day hiding behind the wheel of a 4 wheeler. When I was a kid, I could find one anytime I chose to...meaning if someone wanted to see one, I could scare one up for them in less than 10 minutes.
I always wear leather gloves when I reach into unknown and untrusted places.
Assuming black widows are merely spiders after all*, some of these things could work for you:
How to Repel Spiders | eHow.com
Edit: The comment marked with * sounds like I am being a smarty, so I popped back on to say I am not sure that they are not special in some ways, and I am only assuming they are merely "a spider" and that things which deter most will deter black widows.
I get that they are around and I'll have to exercise caution. I'm concerned about the well house specifically as it's relatively undisturbed place I'll be putting my hands in several times a year. I can't really get a good look at the underside of the equipment that's in there. In this case, if the spider had been under the pressure switch (where it ran to) instead of in the middle of it's web, I never would have seen it and would have attempted removing the pressure switch. That spooked me a little bit.
This is in Southeast Virginia. Between the four houses in my immediate family, there are three different style well houses - this one sunk into the ground, one completely underground (I believe it was built into a precast septic tank) and two above ground. Pretty much everyone around here has been put on city water in the last (?) 20-30 years, so the wells are either mothballed or used for watering gardens.
Keith
/ Black Widow deterrent #6
The only thing I've found is to spray with a spider approved residual pesticide 3-4x per year.
I'm using a generic form of deamon (Cypermethrin). Seems to be very deadly if you have more than 4 legs, but relatively low toxicity to mammals.
Keeps the bug volume down in the garage and basement too.
/ Black Widow deterrent #7
Keith
When I was a kid, I had to seal our pressure switch. Ants would walk up the wires, get into the switch, and invariably get on the contacts. Once the contacts slapped shut to start the pump, the ants get crushed and electricuted. New ants replaced, and before long the contacts would not conduct electricity.
Thinking about it myself, I was wondering what Texas Pete, black ground pepper, etc would do to a spider. I would not use pesticide unless there is no chance of anyone drinking the water, since all casings have a vent, and every time the pump runs, the casing has to take a "breath."
/ Black Widow deterrent #8
I have no idea how to keep them away, but your question got me thinking. I used to run a horse farm that had them absolutely everywhere. I only see them occasionally on my farm now. Of all of them that I've seen, and we're talking thousands here, I've never once seen one that was acting even slightly aggressive. I've had them on my hands and arms probably a hundred times and they just simply crawl off.
Has anyone else seen them aggressive? At first, they bothered be because all I thought of them kinda like a rattlesnake, but now I don't bother with them at all.
/ Black Widow deterrent #9
It does not deter spiders/wasps/etc., but most aerosol de-greasers (CRC for example) will almost immediately kill any insect. For me, it works better than products marketed for that job.
Does application of said aerosol typically include a lit match? :)
/ Black Widow deterrent #11
There are some aggressive species, but in the US, they are not aggressive, and people get bitten by:
Hurting them physically, like mashing them, etc, but not enought to kill them outright.
Their eyesight is poor, so sometimes a person will get a finger on their web, and they rush to bite thinking it is an insect.
I studied them pretty good because of this thread, and their poison is a neurotoxin, so it can be remedied, usually with no damage. Then I studied the Brown Recluse, and they use a cytotoxin, and those are the ones that frighten me. Even those, it is claimed that 90% of the time, people have no issue, but I have see cases when large massed of flesh slough off...and sometimes that actually leads to death.
In my study...I got the answer to one question...I have seen BW spiders with a yellow hour glass instead of red. I was concerned it is a different spider, but it turns out that the male has the yellow, and their poison glands are considerably smaller.
/ Black Widow deterrent #12
Interesting to know. Thanks for the education.
I've known a couple of folks who were bitten by a brown recluse. I've seen the damage they can do and avoid them like the plague.
Caterpillar Service Letters from 1980's (A63117)
Caterpillar...
2022 John Deere 616R Sprayer (A63111)
2022 John Deere...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
RAIN FLOW 1 PANEL SLEAD BEDDER BED PRESS (A63291)
RAIN FLOW 1 PANEL...
