bcarwell
I have a B7500 subcompact Kubota tractor.
Everything was running fine. Then about a month ago it sat for 2-3 weeks during heavy rains. When I went back to start it, there was black smoke at startup, then it ran for 15 seconds or so and quit. In trying to start it again right then, I see much more black smoke and it won't start now.
Could you please indicate to me in order of most likely to least likely what the cause might be ? I'm hoping that at the top of the list is bad fuel maybe with some water or condensation, as the fuel was fairly old and in heavy rains and if that is the case, how do I drain it out ? Is it simply checking the fuel filter and detaching the fuel line somewhere or is there more to it to make sure its out of the tank ?
I am aware of several other possible causes: dirty injectors, timing (pump injector), plugged air inlet, plugged crankcase vent, valve adjustment, atmospheric sensor, auto timing advance, etc., etc.
But what are the most LIKELY other causes and ones that, not being a diesel mechanic, I could diagnose and check for, and ideally at least take a shot at fixing without getting knee deep in a shop manual, etc. with limited tools ?
I just want to give it a shot before calling a mechanic in out here where God lost his shoes....
Thanks for any help !
Bob
Bob
