Black sludge in Hyd Loader Lines and Valve
   / Black sludge in Hyd Loader Lines and Valve #1
gt14
Aumsville Oregon
Yanmar YM146 YM165D
I have Black sludge in Hyd Loader Lines and Valve assy. I have cleaned the valve. But how could I clean the lines. The loader I have has the hydraulic fluid inside one of the arms of the loader intself. I think it is a YFL-140 and it runs off a Hyd pump driven by the front PTO.
   / Black sludge in Hyd Loader Lines and Valve #2
Is there a filter in the system? If not I'd recommend putting one on. There could be rust from the inside of the arms if the tractor had sat for a while the only alternative to t dissassembling everything & manually cleaning them would be to install a filter. I have one available if you need one.
The loader is a YFL-155. The hydraulic fluid is stored inside one of the arms of the loader. Does anyone know if it uses standard hydraulic fluid of some other. Also it does have a strainer but not a filter like what is one a tractor. The strainer was competly black and covered with sludge I currently am running water through the arm holding area before I add new fluid.
   / Black sludge in Hyd Loader Lines and Valve #4
Use a hydraulic oil in it. It would be better to use something like diesel fuel to clean it. Make sure it is dry before filling it.
PAIR OF FILING CABINETS (A53843)
PAIR OF FILING...
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
Ford Super Duty FX4 Pickup Truck Bed (A51692)
Ford Super Duty...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2009 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2009 Jordair...
