Bison S650g Tractor seal
   / Bison S650g Tractor seal #1
beagledog
virginia
case
Where to go to get a Bison S650g Tractor pto seal. Number on the seal is TC 55 70 9
My seal started leaking and needs replaced. Haven't found one.
   / Bison S650g Tractor seal #2
This translates to a seal that is 70mm outside, 55mm inside that is 9mm thick.
Search for 55x70x9 oil seal. Numerous available online.
Should be able to get it at NAPA or other auto parts store with a knowledgeable staff.
BTI
   / Bison S650g Tractor seal #3
BTI
I guess I should have said that it translates to a seal that is 55mm inside, 70mm outside, that is 9mm thick.
That keeps it with the number designation better.
Went to 5,auto parts stores and no luck
   / Bison S650g Tractor seal #5
This is where I order my seals. Never had a problem with ordering from them. When you click and pull up the product, in the description it gives nominal A size and a nominal B size for the inside and outside size. This number is sometimes misleading. Always go by the size that you type in for the measurements. This link provided is for a metric size 55 ID...70 OD...9 Thickness... Type oil seal. Hope this helps. They usually have pretty quick shipping which is also reasonably priced.
Hydraulic cylinder repair seals and kits-Hercules Sealing Products - Hydraulic Seals and replacement cylinders for construction and many other heavy equipment industries.
   / Bison S650g Tractor seal #6
Hi Beagledog
Do you remember where you got the PTO oil seal?
Mine just started leaking and I need to replace it.
How did you get the old one out?
Any tricks you would like to share?
   / Bison S650g Tractor seal #9
Contact Valley Power , they can likely help.
Have you replaced the PTO seal on a Satoh Bison? Not sure how to get the seal out.
I tried taking the PTO shaft out and I think that was a mistake. I put it back together and now the shaft wobbles when in gear.
   / Bison S650g Tractor seal #10
Wish I could help you on this, I don't have any personal experience with this though. I would again recommending calling Valley Power, they are probably the most accessible and knowledgeable source of Satoh parts and repair information.
2012 KENWORTH T600 SERIES (A52472)
2012 KENWORTH T600...
JLG MANLIFT (A52472)
2013 VERMEER VACTRON LP555 DT HYDROVAC TRAILER (A52472)
2013 VERMEER...
2020 JOHN DEERE 8R310 LOT NUMBER 210 (A53084)
2020 JOHN DEERE...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
