Bison Pump or Simple Pump
   / Bison Pump or Simple Pump #1
RichZ
Veteran Member
White Creek, New York, Washington County, on the V
Kubota 4630 with cab and loader
My wife and I would like to have one of these hand pumps installed over our drilled well. I know they can be installed over the electric pump and can be used in case of power outages. It seems the Simple pump can be connected to your water supply and you can hand pump water into your pressure tank so you can still use your plumbing during the outage. I'm not sure if you can do that with the Bison pump. Does anyone have wither of these pumps? What do you think of them?
Thanks!!!
   / Bison Pump or Simple Pump #2
I've been told that the "pitcher" pumps with thier open top for priming are "NOT ACCEPTABLE" as the opening can introduce all kind of nastys into the well casing.
   / Bison Pump or Simple Pump #3
How deep is your drilled well? a single line pump won't work over a certain depth... I believe 26 feet. There's also the consideration of the poster above me...
How often does your power go out? A generator with transfer switch can accomplish the same goal, power more than your pump, and unless you go with a whole house you can accomplish it for the same or less money than a Bison.
   / Bison Pump or Simple Pump #4
I hadn't heard of hand pumping into a pressure tank. It doesn't seem feasable to me as at minimum pressure one wouild be working against a significant pressure. Commonly 28PSI (tank emptyi) to up to 60 PSI.
Yes suction pump is only good to about 25-26 lbs at sea level - less as altitude increases. It is possile - I don't know if it is done - to have a handpump for deeper wells but the pumping mechanism wouild have to be at the end of the pipe and run by a long rod to the handle. Back pressure problems also could be aproblem.
   / Bison Pump or Simple Pump #6
Even if you have a 4" well I don't think you can get 2 pump pipes in the same casing. I have a 4" well with 2" pipe so I'm certain I would never be able to get this pump in my casing.
   / Bison Pump or Simple Pump #8
It's the same style of pump that wind mills used to pump water and the old hit and miss engines.
RichZ I don't have one but did seriously look them for backup.
But my second well is a dug well and if both the pumps are out I can use a bucket and a rope to draw water.
   / Bison Pump or Simple Pump #9
I still think that a generator and transfer switch would be more economical, but that's just me.
   / Bison Pump or Simple Pump #10
Those pumps have sucker rods like a windmill and can pump from quite a depth. However, hand pumping into a pressure tank is a big challenge. You would really need a shower by the time you get 20 gallons pumped into a pressure tank. Usually best to just fill a bucket at the well head. The generator idea is best for long term power outages. It can run the pump and keep the freezer from thawing out at the same time.
Another idea is to use a retention tank prior to the pressure tank. The water will continually flow through the retention tank on the way to the house and will be good fresh water when the power goes off. Then with a retention tank full of water, you can either use a battery powered RV type pump to supply the house, or use a battery powered air compressor to force water out of the retention tank and into the house.
1996 Eager Beaver Lowboy Trailer (A45336)
1996 Eager Beaver...
2017 FREIGHTLINER CASCADIA (A45046)
2017 FREIGHTLINER...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A44571)
2023 Caterpillar...
(6) Planter Wheels (A44502)
(6) Planter Wheels...
Case IH Farmall 95 (A44501)
Case IH Farmall 95...
2003 VIKING  CEMENT MIXING TRAILER (A45333)
2003 VIKING...
