Bison 650g distributor wiring
   / Bison 650g distributor wiring #1
daveburgoon
Ekron, KY
satoh 650g
OK, got a new engine to install in my Bison, but ran into the slightest hesitance... The previous engine had a mechanical distributor, this one has an electronic distributor. Quick question and this will sound silly to some one (my apologies). The previous distributor cap had one wire to the coil and one to the condenser. This one has a black wire going to the coil and a red one hanging free. I think my mental block is because I'm used to red going to hot (or the coil in this case) and black going to ground. However, anyone who wants to make me feel more at ease (or dumb), please confirm that the red should be grounded... That's where I'm heading tomorrow... Enough for tonight. I'm just praising God that I have a good turning engine and that by His grace, tomorrow I'll have an engine that fires up!
   / Bison 650g distributor wiring #2
It sounds like the black wire is the signal wire telling the coil when to fire. The red is probably for power for the distributor from the ignition switch.
There would be no need for a ground wire since the distributor is grounded. This is just an opinion, so I would find out for sure before making any connections.
Dave
Actually, that makes sense now that you put it that way. I'll do some more research like you said, but that would make sense. Thanks!
Yup, she worked. Got her to fire up by God's grace.
   / Bison 650g distributor wiring #5
Congratulations. Good to hear. Thanks for posting your results to let us know it worked.
Dave
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2003 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2003 CATERPILLAR...
Ingersoll Rand PKG SS3660V 60 Gallon Air Compressor (A52377)
Ingersoll Rand PKG...
CASE 580 (A47477)
CASE 580 (A47477)
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
