Bird Houses
   / Bird Houses #1
LilRhody
Bronze Member
Rhode Island
John Deere 4100 HST
Thinking about building a Purple Martin bird house. I have been researching them, but, have not read any 'real life' accounts on housing these creatures. I know the difference between Theory & Reality...My question: How imperative is it to erect a house in an open field? I have a spot along my tree line that abuts my side yard. I was hoping to place the house there for aesthetic reasons. I'm open for suggestions, however, my woodworking skills are very limited.
P.S. I'm sure Bird may have a tip or two on what to build:)
   / Bird Houses #2
<font color=blue>sure Bird may have a tip or two</font color=blue>
Nope, don't have any myself./w3tcompact/icons/laugh.gif However, a good friend (long time co-worker) and his wife are avid bird watchers and they have several Purple Martin houses on a small lot in town, so I'd say being in an open field is not necessary. The thing that is necessary (or so I've always been told) is to have them as high as possible and that it's absolutely necessary that you have them on telescoping or breakover poles (or some other arrangement) so you can regularly get to them because if you don't regularly clean out the sparrow nests to prevent them from nesting there, you'll never have Purple Martins.
   / Bird Houses #3
I’ve been told that with out a water source---pond, stream---near by, it is unlikely you will attract Martins. I don’t know if that is fact but my father-in-law has always said that. He has always used gourds for Martin houses.
MarkV
   / Bird Houses #4
i have 6 martin houses, and usually have martins very early every year; what Bird says is true..you also need a clear path from some direction..they like to glide into the box. i actually have 8 boxes, 2 are home made, very nice houses, 12 holes, the holes are the right size and all that stuff; but when a local hardware store went out of business, i bought their metal houses, and the martins haven't built in the wooden houses since..probably 8 years...last year wallyworld started selling martin houses made from pvc; they look really good, and are cheap, @ $30; but it takes a triangular pole, which cost another 30 or so..this will be my second year with this type house, and i'm not real impressed yet..the roof is dark green, which i think causes it to get to hot..but i have them up and will try them one more year..if i don't get any better results, they will be sold and i will get some more metal houses.
when i bought the metal houses, the store had a beautiful redwood martin house, i bought it too; went for 4-5 years and only saw one martin even go inside the dern thing, so i took it down an painted it white, left it up for 2 more years, and finally gave it away..
heehaw
   / Bird Houses #5
there are several things to keep in mind if you want birds to populate your house(s). As HeeHaw noted ... Martins are pretty finicky. And they go back to their last nest site unless they die or it's already populated. So ... usually, you end up attracting juveniles who're building their first family.
As with real estate ... location is critical. High up, but ... close to people. Remember, their food source is bugs (on the wing) and bugs like people. The houses that seem to work best are those higher than close surrounding stuff, with wide open spaces but close to a house. Martin houses can do very well in a city or town if the conditions are right.
You need to do a good job cleaning the house before the season starts ... and keep the blasted sparrows out until a martin takes residence ... you get one, you'll likely fill the house - they're gregarious.
Telecoping pole definitely makes life easier.
Good luck!
   / Bird Houses #6
If you had asked how not to do it, I could write a book. Check this link, it has some good information about location and much more.
<A target="_blank" HREF=http://www.purplemartin.org/main/mgt.html> Purple Martin </A>
Al
   / Bird Houses
TwinkleToes, nice web-site you linked. I have a feeling that I'm going to have to scrap the Martin house. If I stick the house in the middle of my field/yard (like the web-site suggests); I do not think the pleasure of watching these birds (that is if I can attract them in two years or so) outweighs the fact that I would have to mow around the pole that the thing sits on. Maybe I'll research an owl box instead (already have bats...lots of bats:))....The research continues............
   / Bird Houses #8
LilRhody, go for the bat houses. They are pretty cool little critters. Did you read the part, where the Purple Martins do not feed on Mosquito's, maybe the bats would do a better job. Bat houses are a lot eaiser to build.
Al
   / Bird Houses #9
My grandfather had a purple martin house (really more like an apartment due to the # of nest-boxes it had in it! ~24) he constructed and put in his yard, at the back of the lot.
He lived in town & always had tons of PM birds. It was up about 15-20' and about 50'-60' from the house, but it was within about 15' or less from oak trees that were much higher than it was. Additionally, it was near (but below) the power lines at the back of the lot (chain link fence with brush along there too.)
I guess they did have a "sailway" over the house and through the yard from 2 directions (his house and backyard neighbor). Don't know if Central Texas PM are less finiky than those in RI, but he always had good luck. (then again, maybe we just have more bugs and lower housing costs down here! /w3tcompact/icons/laugh.gif)
I'd say don't give up until you give it a try - what's the worst that could happen?
   / Bird Houses #10
Since bat houses were mentioned, my wife just brought one home the other day.Is there anything special you have to do to attract bats or do i just hang this thing up on a tree and wait? We always have a couple of bats flying around our house during the summer. Is there some kind of bat bait?/w3tcompact/icons/laugh.gif
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2021 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2021 PRINOTH...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2022 Ford Explorer SUV (A51694)
2022 Ford Explorer...
