Binder Care
   / Binder Care #1
TWD
Sierra Nevada Mountains - CA
Kubota M59
I just replaced my crappy HF binders with forged, made in USA binders.. (4x the cost of the HF unit )
What's everyone doing to keep their binders good to go when you need them?
-Unscrew, add grease inside?
-Unscrew, spray with lanolin (fluidfilm)?
-Unscrew, spray with Amsoil or SeaFoam metal guard \ protector?
What's worked best for you? I have all of the above, and use them for various things, but never on my binders....
   / Binder Care #2
I just keep them stored in a dry box.
   / Binder Care #3
I squirt some engine oil on the threads once a year or so, and store them in a dry area when not in use.
   / Binder Care #4
I use Gear oil, works for me
My binders sit out in the weather year round, never have an issue if I periodically lube them
Fluid film and motor oil work fine also.
   / Binder Care #5
I have a toolbox on my trailer which is drastically better than leaving the screw exposed to the elements. When the screw starts binding which is inevitable I pours some of whatever oil I have laying around on them. I don’t like the grease them because it’s messier.
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
2013 Ford F-450 Altec AT200A Bucket Truck (A50323)
2013 Ford F-450...
Kubota L2800 (A47384)
Woods 3 pt Box Blade (A50515)
Woods 3 pt Box...
