BIGTOOLRACK
Advertiser
- Joined
- Jan 14, 2009
- Messages
- 232
- Location
- Lakeside CT
- Tractor
- Kubota L4760 Cab Tractor 1105 Loader 72 heavy duty bucket, WildKat Root Grapple, Land Pride Pallet Forks Scag Cheetah 61 34HP Kawasaki
Check out the NEW Bigtoolrack XPHD
Visit Compact Tractor Attachment | Tool Organizer | Hitch Cargo Box | BigToolRack
$899 Delivered right to your door! Why waste money on a useless weight box......
BIGTOOLRACK IS THE ULTIMATE TRACTOR ATTACHMENT THAT ADDS COUNTERWEIGHT YOU NEED, THE ABILITY TO TOW A TRAILER, AS WELL AS SECURELY CARRY ALL OF YOUR TOOLS!
Product Details & What's Include:
1 drop down hook
1-4 Hole tool holder
1 Universal tool holder with Rubber Strap
1 counter weight bracket
All attaching Hardware
Rack Dimensions L: 43" x W: 46" H 38"
Bed is made of a durable rotomolded HDPE double wall plastic that is built to last and will never rust, supporting spine and side compartment with cup holder, beavertail end. The body also has drain holes in it so it will not fill with water.
Powder Coat Finish on yellow upright bar that is setup to accept many of our Bigtoolrack Accessories
This Rack has a max cargo capacity of 600 LBS with our 3 point hitch setup. Be sure to check your owner's manual to see what your vehicle is rated for, you are never to exceed your vehicles rating.
3PT Hitch connector comes standard with our suitcase weight bracket that holds up to 6-42 LB suitcase weights for added counterweight. Weights NOT INCLUDED.
Standard Tow feature this gives you the ability to tow a small trailer around with the Bigtoolrack when connected to your tractor, like a log splitter or small utility trailer. Tongue weight not to exceed 75LBS
*Tools and Accessories Not Included*
1 drop down hook
