Bigtoolrack Launches NEW Rack BIGTOOLRACK XPHD Order Today!
   / Bigtoolrack Launches NEW Rack BIGTOOLRACK XPHD Order Today! #1
BIGTOOLRACK
Advertiser
Lakeside CT
Kubota L4760 Cab Tractor 1105 Loader 72 heavy duty bucket, WildKat Root Grapple, Land Pride Pallet Forks Scag Cheetah 61 34HP Kawasaki
BigToolRack XP
from 599.00
Note: Choose XP HD 3PT Hitch Version to add counterweight and tow feature
Product Details & What's Include:
Rack Dimensions L: 43" x W: 46" H 38"
Weight 109 LBS for the 3 point model and 75 LBS for the 2 inch receiver model.
Bed is made of a durable rotomolded HDPE double wall plastic that is built to last and will never rust, supporting spine and side compartment with cup holder, beavertail end. The body also has drain holes in it so it will not fill with water.
Powder Coat Finish on yellow upright bar that is setup to accept many of our Bigtoolrack Accessories
This Rack has a max cargo capacity of 600 LBS with our 3 point hitch setup or a 100 LBS capacity with our 2 inch receiver setup. Be sure to check your owner's manual to see what your vehicle is rated for, you are never to exceed your vehicles rating.
3PT Hitch connector comes standard with our suitcase weight bracket that holds up to 6-42 LB suitcase weights for added counterweight. Weights NOT INCLUDED.Why waste money on a useless weight box! Get more out of your tractor!
3PT model comes standard with our tow feature gives you the ability to tow trailers with low tongue weight around with your tractor like a log splitter or small utility trailer.
Visit
Compact Tractor Attachment | Tool Organizer | Hitch Cargo Box | BigToolRack
2013 Ford Escape S SUV (A48082)
2013 Ford Escape S...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2006 Gorman Rupp 14C2 10 Series Self-Priming Centrifugal Towable Water Pump (A49346)
2006 Gorman Rupp...
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
2011 Ford Crown Victoria Sedan (A48082)
2011 Ford Crown...
2018 John Deere 460E Articulated Dump Truck (A51039)
2018 John Deere...
