BIGTOOLRACK FALL PROMOTION
   / BIGTOOLRACK FALL PROMOTION #1
BIGTOOLRACK
Advertiser
Lakeside CT
Kubota L4760 Cab Tractor 1105 Loader 72 heavy duty bucket, WildKat Root Grapple, Land Pride Pallet Forks Scag Cheetah 61 34HP Kawasaki
TBN Members Place your order today and Save 10% on your whole order... Enter Code BTR10 in the coupon section at checkout.
BigToolRack is a versatile tractor attachment that adds a few much-needed features to your tractor. Counterweight, ability to tow a trailer, as well as carry all of your tools!
Turn your tractor into a UTV!
Finally an attachment that will securely carry all of your tools!
The versatility is endless!
Attach your BigToolRack to your Tractor using the standard 2 inch male end or use our optional 3PT hitch kit. Once the BigToolRack is attached there are countless items you can connect to it using the 2 inch female connector, you can tow a trailer pull your log splitter whatever your needs are BigToolRack is there to help! No more running back and forth to your garage or barn to get the tools you need to do the job! Buy the attachment you will never want to take off!
Bigtoolrack offers counter weight, the ability to tow a trailer once attached and allows you to securely carry all of your yard tools and power tools. Why waste your money on a useless weight box that is only good for one thing. . . and is very hard to move around when you take it off!
Compatible with All (category 1) 3-Point Hitch's or
2 Standard 2 Inch Receivers
Large Cargo Area Length: 47" Width: 27" Height: 43"
Bed Inside Dimensions Length 45 Width 25" Bed Depth: 14"
Bed is Heavy Duty Steel Construction
Unit Weight 300LB
Capacity 600LBS
Powder Coat Finish
2" Male Tube to connect to your tractor
2" Female Receiver to tow a trailer once attached
Active Tail Gate with cables that can be easily removed
3PT Hitch Kit *I-match compatible*
Custom tool holders with rubber straps
4 Hole Long Handle Tool Holder
Handy Storage bins
Drop down lumber carriers
Drop down Universal Rope-Power Cord-Garden Hose Carriers side mount
Grass Trimmer/Pole Saw holder
Chainsaw Holder
Deluxe Wheel Caddy Kit adjusts up and down attaches and detaches without tool converts your rack into a mobile storage system.
VISIT our website bigtoolrack.com to get more information.
Check our video out on our homepage to explain more about the BIGTOOLRACK
2025 25ft. 800Amp Extra HD Booster Cables (A48081)
2025 25ft. 800Amp...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
Toolbox (A50860)
Toolbox (A50860)
2012 Hyundai Genesis Sedan (A48082)
2012 Hyundai...
2013 Chevrolet Silverado 3500HD Crew Cab Omaha Service Truck (A48081)
2013 Chevrolet...
2012 Mercedes-Benz C250 Sedan (A48082)
2012 Mercedes-Benz...
