Bigger Bags on Bagger????
/ Bigger Bags on Bagger???? #1
jerkyboy
Upstate NY
I just installed the Kubota bagger set up on my BX1500 and was wondering if anyone installed bigger bags in place of the stock units. There is lots of room left for the baggers to hang before they are at ground level so I was wondering if anyone has adapted bigger bags to the stock system; and if so, what was used as replacements and if any modifications are necessary?
/ Bigger Bags on Bagger???? #2
I have thought about, but not yet acted on, looking for taller bags...but I only use my bagger for fall leaves. If you use yours for grass clippings, I suspect the weight with bigger bags could cause steering problems. The engineers probably took this into consideration when they selected bag size.
2020 BOBCAT T650 SKID STEER (A62129)
2020 BOBCAT T650...
2023 Case TV380 (A62177)
2023 Case TV380...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2008 Down to Earth Trailers DTE7610G29 10ft. S/A Utility Trailer (A61569)
2008 Down to Earth...
