Big lean too
   / Big lean too #1
millwrightdude
I'm getting ready to build a lean too off my 40x30 barn to park the tractor and the truck. My plains are to build it 40x30. I have acquired (3) 30ft 8in wide flange I beams. I will be using 4x4 1/4 wall posts. I plain on making it a clear span and will be using 8in c perlin on top of the I beams. My ? is the I beam strong enough.
   / Big lean too #2
I'm a ca. gen contr. Lots of wind uplift on lean to. Kinda like a wing in the wrong situation. Suggest You find a structual engr. 4x4 sounds light. I'd worry about hitting one post with equept. and eating a roof. I'd go with 4" pipe bolted into conc. footings,at base. Use a simpson bucket on top bolted. Maybe You can locate salvage pipe. In a commercial area ,You may see similar detail that was engineered. This will give Yoy some help. Also consult a good builder in Your area, He may have worked on a similar project. Good luck
   / Big lean too
My plans are for 4x4 square tubing. I would hope that is strong enough.
   / Big lean too #4
I think using three beams to support roof that is 40 feet long is going to be a problem. One at each end, then the third in the middle means your purlins will have to spand 20 feet. From what I've seen, 16 feet is about the max distance for purlins. Have you checked the distance your purlins are rated for?
I use a company called Muellers for metal buildings. They engineer everything and size it for me. Who are you buying your metal from? If it's a metal building company, they should have an engineer in house who can tell you the size and loads of there materials.
Eddie
   / Big lean too #5
Sorry missed the metal part,plenty strong,on the posts. Eddie raised a good point on the span !
   / Big lean too
I did check about the perlin,and 8in should be more than enough. I called mueller and thats is what they said. I did not ask about the I beam
24008 (A53422)
24008 (A53422)
2014 Ford Escape (A50323)
2014 Ford Escape...
New Holland B95 Backhoe (A50490)
New Holland B95...
CHERRY PICKER AND TRANSMISSION JACK (A53843)
CHERRY PICKER AND...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
