When people say "Brush Hog" or "Bush Hog" in a general sense they are usually referring to a single spindle 3-pt lift type rotary cutter. With a 10' cutter you're jumping to 3 spindles which is okay. But more importantly, you're jumping quite a bit in weight. Of course more weight and more spindles means a
LOT more money! I have a 10'
pull-type cutter. I pull it with a 68hp (62hp PTO) tractor. My owner's manual recommends not using a 3pt lift mower heavier than 1200 lbs. But my mower weighs 3200 lbs.! There is
NO WAY I could
lift that thing! If you want to use a 10'
lift mount mower you're going to need a really heavy tractor with good front-end ballast. It will need to have a 3pt hitch lift capacity in the several TON range! You're probably looking at a tractor around 85-90hp. If you want to get a
PULL type mower you could probably get by with less. With my setup I can completely shred 1-1 1/2" saplings beyond recognition!
