Big Case tractors
   / Big Case tractors #1
dodge man
Super Star Member
West central Illinois
JD 2025R
Saw this today on a construction site. Big tracked Case IH tractors pulling scraper pans. It used to be the tracked Challenger tractors doing this but lately it’s been tractors more like these . The building an area for staging and storage for a new power line project. I assume storm water detention is what the big hole is for. I believe there were 5 of these rigs running around.
   / Big Case tractors #2
I've seen that before, it's cool to see those large ag machines working in construction. Given their size and weight, they must do great pulling those scrapers.
   / Big Case tractors
If you look in the first picture there is a wet area, I noticed them spinning a little in this area. It’s been very dry around here, I’m not sure what the plan was if we had a wet fall.
   / Big Case tractors #5
View attachment 4329471View attachment 4329472
That’s because the Challenger line was discontinued about 4 years ago.
What AGCO has done is replaced them with Fendts.
   / Big Case tractors #6
Did AGCO ever make scraper models of twin tracks or was that discontinued when AGCO purchased challenger line from CAT?
   / Big Case tractors #7
Yes. Here’s one with a CAT C-18 motor. It was just the opposite. When AGCO purchased Challenger from CAT, they only had the single track models. AGCO then created a dual track articulating model.
Case-IH has a big hold on my area, so about1/2 the pull-pans are pulled by Case-IH quad tracks. I also see Deere pulling lots of them.
Saw a few Challengers, but they had a bigger presence in other areas.
CAT really was rolling when they had AG tractors and even had trucks going back about 15+ years ago. Then they jumped out because they couldn’t make their engines meet the reliability-killing over-burdensome EPA regs.
Cat's new Quadtrac - Coffee Shop - Red Power Magazine Community
   / Big Case tractors
I did some topographic surveying in front Caterpillar plant when they first started making Challengers. I’m not even sure where it was, I was working for our Rockford Illinois office, it was maybe east of Rockford. That was the first I’d ever seen a tracked ag tractor. My memory was it was a smaller plant but they had a bunch of them outside, maybe this was late 80’s early 90’s.
   / Big Case tractors #9
I have done some digging with a Deere four track. We had to move the dirt quite a ways so we pulled 2 units per machine. Because we only filled 1 at a time it worked. Toughest part was when they were both loaded pulling them up and out of a retention basin. Mine understanding is the Case has a better cab, more operator comfort.
   / Big Case tractors #10
We were using the Case Quads with scrapers in 2000. Had a serious undercarriage failure rate with the 440 model. It showed up new about a week before 9/11 at the new Catholic school on Rt 40. Front idlers would melt the shafts from bearing failures.
I think they improved it when they went to the 450. I believe we started with 2 used 9310's for proof of concept. A contractor in Southern PA was using Cases but with flotation singles. Trouble was that made the tractor wider than the scraper.
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
2025 Swict 78in Bucket Skid Steer Attachment (A55851)
2025 Swict 78in...
2019 Dodge Charger (A56859)
2019 Dodge Charger...
2012 Mazada 3 Sedan (A55853)
2012 Mazada 3...
2004 CATERPILLAR CS-563E SMOOTH DRUM ROLLER (A52707)
2004 CATERPILLAR...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
