Rotary Cutter Big Bee Rotary Cutter
   / Big Bee Rotary Cutter #1
tkcomer
Maysville, KY
JD 3039R
Does anybody have the Big Bee rotary cutter? Any thoughts on it? I’m looking to buy a 6-foot, 3pt rotary cutter for my DX-33 and was going to use it to trim under trees and around fences before I bring out the Case-International 685 and the 10-foot Bush Hog. I’m tired of fighting tree limbs with my muffler. I figure a light duty cutter would be all I need to do the trimming. Sweet Tractors sells this brand and I’m probably about 3 hours away. Plus he has the Herd Seeder that I want. I figure if I make the trip, I might as well make two buys at once.
   / Big Bee Rotary Cutter #2
I have a Big Bee finish mower and I am happy with it.
I bought it used for $250. Put one belt on it so far.
I also have a 16inch 2 bottom plow that I believe is a Big Bee.
I would have no problems with buying more Big Bee equipment.
Pooh Bear
   / Big Bee Rotary Cutter #3
Hey Tim - it's Steve, from we-go. I just saw your post and thought I would say HI. This is a great site - thanks for recomending it! Later - 2kTJ
Hey Steve. Glad you found the site. These guys can figure out what’s wrong with your tractor. Just give them good info. Any other Big Bee owners out there?
   / Big Bee Rotary Cutter #5
Hi Tim,
I've got a Big Bee rotary cutter - 6' that I use on my Jinma 454LE. I am new to the world of tractoring, so, I have no point of reference for other cutters as I have used only this one. With that said, I am extremely pleased with the Big Bee rotary cutter. I use it around my property (approx. acre rough cut), keep all of the common areas in our home owners association cut (approx 8 acres) and neighbors fields and pastures. This cutter has always been able to tackle anything I throw at it - and I get pretty abusive. I cut almost 4 acres for some people up the road a couple of weeks ago. Their field had not been cut in years. There was brush, saplings and weeds higher than the canopy. The cutter took all of it down with no problems.
The gearbox apears to be heavy duty. Seems to be comperable to some of the King Kutter's I have seen around here as far as size and type of build. I have hit some rocks and stumps, shearing the pin right off. Put in a new one and I am back up and running.
Couple of things I like:
Housing is very thick.
Like the reinforcement plates under the gear box.
I have not seen this on others, but, I like the way the top plate is reinforced with the "webbing" - kind of a tic-tac-toe grid around the gear box.
Couple of things I don't like:
The tic-tac-toe grid around the gear box does not allow water to drain off when cleaning. Would have been nice to had some holes for drainage. Probably just need to go ahead and drill some holes - prefer the reinforcement over ease of cleaning though.
The chain that connects the "top down bar" to the back of housing is somewhat cheap. Better design would have been 1) use a heavier chain and/or 2) punch holes in the bracket and bar instead of welding the chain on. The chain links have snapped apart on me - yes, I was driving too fast and the up and down stresses busted the links, but, I still think the chain is to light weight. I have cut off all the chain links with the exception of the 2 welded pieces and replaced with 3000# quick links - have had no more problems. If and when the welded links break, I am drilling 1/2" holes and putting quick links in those as well.
Overall, I like this cutter. It works well for me and what I do; especially liked the price. From what you described you will be doing, think it would be a good fit.
-Eddie
   / Big Bee Rotary Cutter #6
I have a 48" Big Bee RFM and it works great. When I got my Kubota L175 an older one came with it. Liked it well enough to buy another one when the old one rusted through. Locally a new 48" Big Bee RFM was $1095 MSRP but paid $895.
Hey gang. Thanks for the answers. Sounds like it is a tougher cutter than I thought. I just need it to make the initial trim around the trees, but you know how limbs get piled up around those. Wife says she can help me mow. She loves the DX. We’ll see about that. I bet she’s gone at the first sign of spiders. And we have a lot of those in Kentucky.
2012 Chevrolet Colorado Ext. Cab Pickup Truck (A55852)
2012 Chevrolet...
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2012 SCOTT MANUFACTURING SAND CONVEYOR (A55745)
2012 SCOTT...
