Rear Finish Mower Big Bee Finishing mower belt
   / Big Bee Finishing mower belt #1
DaveBlock
Louisville, KY
FarmPro 2425
The belt for my 48" Big Bee finishing mower keeps breaking.
   / Big Bee Finishing mower belt #2
Breaking or burning through itself? Was it adjusted too tight or too loose?
First thing I would check is that all the pulleys and idlers are turning smoothly, then make sure that they're all lined up with each other. Might also look them over closely to make sure none have burrs or sharp edges.
If all those check out, is it possible to leave the covers off so that you can watch the new belt in action?
   / Big Bee Finishing mower belt #3
Besides response from Gunny are you using OME belt(s) ? I've seen folks go through more belts trying to save a buck using for instance Huskee Kevlar belts from TSC instead of OME belts. Just mention that brand from what I've knowtised doesn't mean others have not success with that brand or other aftermarket parts/etc.
Boone
   / Big Bee Finishing mower belt #4
I've got a 60 inch Big Bee finish mower. I had a problem breaking belts. All the pulleys are in excellent shape. The arm that the tensioner pulley is on was slightly loose. The belt tension would pull it off kilter a little bit causing the belt to come off and get chewed up or break. I solved the problem by tightening the bolt that holds the idler arm to the deck.
Pooh Bear
Manac Walking Floor Trailer (A50322)
Manac Walking...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
Pallet Fees (A50775)
2012 MACK CXU PINNACLE (INOPERABLE) (A52472)
2012 MACK CXU...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
Super Material Lift MH1000 (A52748)
Super Material...
