Big Bee Agri-Five Rotary cutter
   / Big Bee Agri-Five Rotary cutter #1
Joe13
York, ME
Kubota Grand L 4060
Hey all,
I have a question concerning my big bee agri five rotary cutter. I picked it up off of a neighbor for cheap, and it had been sitting in a field on the ground for about 10 years. I fixed the PTO shaft, new bearings and ran it. It cut really well, then I ran over a metal pipe. no damage occurred, but one of the blades is no longer rigidly mounted. I used it a couple times after this happened and the only thing I noticed was when I initially engaged my pto, the tractor would wiggle a bit. once spinning, no problems. cuts fine. I assume the wiggle is from the blade needing the centripetal force to go from partially folded in to straight out.
anyway, I had parked the cutter over the winter, brought it into my garage this spring to give the gearbox a oil change, clean up the scale, cut a hole and try and tighten the blade so its rigidly mounted like the other one. Problem I am running into is that the nut is seized something fierce. It has defeated my 1/2" impact, a breaker bar with a 4 ft cheater, and several shots of Acetone/atf mix. My next step will be heat, but my question is this: How bad is it to run with the blade loose? I am not mowing a large area, I highly doubt that it will loosen up and come flying out, and once running it doesn't seem to have a adverse effect on the tractor. I know some rotary cutters have blade setups that fold in, so this is why I am asking.
My overall obvious goal would be to get it tightened up, I just don't know how long that is going to take. trying to get some clarification since I am relatively new to tractors and big equipment like this.
What it looked like when I got it.
the offender thru the new hole I had to make.
Any help you guys can provide would be great.
   / Big Bee Agri-Five Rotary cutter #2
Here's what it seems like to me....most of the Bush - hogs I've run including the larger 15' ones all have blades that fold. The bolt you are trying to tighten can only be tightened so much. The bolt itself along its shank from the head.... (under side of the blade ( is smooth so the blade can spin open and closed....reason is so if you strike something like a rock or stump the blade will fold and not cause more damage. Now if the other blade on your machine is stationary it is most likely sized or rusted in place. That is the one I'd be more concerned with. Having a stationary blade and one operating ad needed puts undue stress in the gearbox and bearings and over time will fail. Try heating up the blade where the bolt passes through and see of you Caan get the blade to move. It might be easier from the bottom. Hook it up lift it up and block it up if you decide to get underneath. Good luck.
Thanks,
When they were both stationary it worked great, but like you said they were probably frozen. I bet I can it the other one and see if it will come free. If so, game on. Will just need to re-fill the gear box, give it a good paint job and get it into the weeds again.
   / Big Bee Agri-Five Rotary cutter #4
Good luck!!. Keep me posted. Also try soaking the bolt in diesel. Soak a rag and wrap it around the part for a few days. You'd be surprised what it can do.
After a bit of frustration, some help from the wife, a lot of hammering and clearing debris with a pick, I got the other blade decently free. years of grime and crap just built up and rust-welded it together. Filled the gear box with new 90 weight. now to get some time to hook it up and test it out. if it seems to be working fine, ill cut with it, then clean it up again and prep it some more for paint. Thanks for the help!
Just got back in from running it. Sort of a slight shake on inital start of the PTO, but runs smooth after that. make sense that would happen as the blades need to stretch out. Other then that, cuts and runs well. with the grass cut i can focus on getting it cleaned and painted now.
   / Big Bee Agri-Five Rotary cutter #8
My Land Pride 5' usually wiggles & shimmies a bit when you start it up & has done that since day 1. It sorts itself out in under 10 seconds whether you leave it at idle or wind it up to PTO speed. Just normal behavior as the blades get pushed out by the rotation unequally.
2001 Ford F-250 Ext. Cab Pickup Truck (A44572)
2001 Ford F-250...
2015 WESTERN STAR 4900 TRI AXLE (A45046)
2015 WESTERN STAR...
2016 Dodge Ram 2500 (A44501)
2016 Dodge Ram...
2023 EAST TEXAS TRAILER (A43004)
2023 EAST TEXAS...
Exhaust Cover (A44502)
John Deere WHP36A (A44502)
John Deere WHP36A...
