Bidirectional wood splitter
   / Bidirectional wood splitter #1
samogreen
Athens ga
kubota kx-057
I would like to find a Bidirectional wood splitter for a kubota kx-057. Check out the you tube video by gzHRFCAQ-q2RD-iXAPObQ 5 mo. ago,or just search you tube for bidirectional wood splitter on a Kubota KX-071. I can add my quick coupler if necessary.
   / Bidirectional wood splitter #2
All the bi-directional splitters I have seen are in Europe. Most seem to be for small wood, like 12 inch stuff. The idea of bi splitters is good. The application is tough. If you are splitting "normal" sized wood. (18-24 inch), you need larger cylinder. Not sure what your needs are but you may consider cycle times as your need. Bi-directional splitters were designed to reduce cycle times in small wood. In order to do this on large wood, cost may become prohibitive. At least for me..... Bi directional splitter cylinders of larger size can get pricey.
   / Bidirectional wood splitter #5
Is this considered a bidirectional wood splitter? It splits both ways
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
Miles read : 112,969 (A50323)
Miles read ...
17101 (A55787)
17101 (A55787)
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A55788)
2012 Dodge Ram...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A54607)
2019 TEREX PHOENIX...
