BH92 - L4400
   / BH92 - L4400 #1
maps
Rutherford Co., NC
Kubota L4400, 1937 John Deere A
I've copied this from the Attachments Forum in search of added insight.
So, it seems somewhere between 2007 and 2008 kubota L4400s changed...the post-change tractors are L4400DT-1. I learned this lesson the hard way by taking my 2007 4400 to the dealer so they could install a backhoe subframe. This summer I found a practically new BH92 backhoe with hydraulic thumb and two buckets for $6K. Everything I read and everyone I talked to (including the dealer) assured me the BH92 would work with my L4400. It seems the subframe that fit my tractor is no longer available. I made a trip to the dealer today to see the differences myself. Looks like fairly significant fabrication would be required to make the subframe for the -1 tractor work on my tractor. So potentially, I have a really nice BH92 without the ability to hang it on the tractor. The dealer said the older hoe and subframe were built by a third party supplier (ASI?). For now he is trying to come up with the company who manufacture the backhoe and subframe spec'd for pre-2008 L4400s (the BH90A) to see if a BH92 would fit the frame that will fit my tractor (if the frame is still in production/available under some other label). A question for the group: can an owner of a Kubota BH90A measure the vertical and horizontal dimensions between the 4-point attachment locations? Thanks. Dave
   / BH92 - L4400 #2
when I got back from Iraq I traded in my L3400 for a L4400. I have been tossing around the idea of getting a back hoe for it. Now I been looking at some ones on the internet and the question I have is will ones from Liberty or Woods back hoes work or is this subframe on my 2008 a deal killer?
   / BH92 - L4400 #3
It evidently depends on whether your L4400 is the updated model or the older one. Hopefully you have a knowledgeable dealer who can get you linked up with the right subframe.
By the way, thanks for your service. Always proud of our veterans and appreciate their service.
   / BH92 - L4400 #4
Hello, maps. ^ I'll echo Grandad4s advice - work through your dealer to get the right bits and pieces to get the mounting for your sub-frame set up right, so you can start using that hoe the day it arrives. About a tear ago, my dealer (John Rebillard, over at R&S Torrington) used the internet, the mountain of 3 ring binders he has in his office, and a lot of phone calls to people he knows at Kubota to sort out the attachment fittings required to mount a BH92 to my 2007 L3240. It was worth the wait and when my tractor came back from their shop, everything worked and fit up perfectly. I think 2007 seven was a transition year, as there was no -1, -2, -3 nomenclature when I bought the tractor. By the way, it's a great backhoe that goes on & comes off in about 3 to 4 shakes of a lamb's tail.
Hope you get it all sorted out - let us know how it goes.
Jim
   / BH92 - L4400
Still holding out hope for a Kubota solution. Chatted to my dealer today and he may have a lead on a subframe that has been sitting at another dealer's lot for quite some time. Otherwise, I've talked with a couple fabrication shops who are confident they can make something work. Will let you know. Dave
2019 FREIGHTLINER M2 26' BOX TRUCK (A51247)
2019 FREIGHTLINER...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
2010 Chevrolet HHR SUV (A51694)
2010 Chevrolet HHR...
2018 John Deere 8400R MFWD Tractor (A53342)
2018 John Deere...
KUBOTA B7510 TRACTOR (A51247)
KUBOTA B7510...
