BH90 w/ T&T
   / BH90 w/ T&T #1
JimMorrissey
Veteran Member
Southern Maine (now)
'05/'06 L39 TLB
Does anybody know if adding a BH90 to a L3830 with T&T is feasible? I believe I would have to remove the hydraulic lift arms and the top link when the BH90 is installed. /forums/images/graemlins/confused.gif It would be a major pain in the rear to remove all the hydraulic components to install and remove the backhoe. I am hoping to be able to switch between a BH and a box scraper fairly often this spring (twice a week). Hopefully I'm wrong and there is a relatively easy solution available.
Any info would be appreciated.
Thanks,
Jim
   / BH90 w/ T&T #2
<font color="blue"> It would be a major pain in the rear to remove all the hydraulic components to install and remove the backhoe. </font>
Jim,
I can't speak on the BH90, but I have not found it much of a pain to remove my hydraulic top link and the two tilt cylinders on my tractor when putting the 3PH BL4690 backhoe on my B2910...
Of course, the T&T is new and I only put the backhoe on once so far. Might take five minutes to take the cylinders off and put the normal lift rods back on.
Basically not an issue from what I can see... /forums/images/graemlins/smile.gif
I guess I should say that I do have quick connects for all the hoses located conveniently on the rear of the tractor. Without them, it would be a different story.
   / BH90 w/ T&T
H, Thanks. That's what I wanted to hear /forums/images/graemlins/smile.gif
   / BH90 w/ T&T #4
jim - Give me the measurement of how far out the t & t sticks out past the rops & i will measure my bh90 which is mounted
   / BH90 w/ T&T #5
I have a TnT on a Kubota B7610 with a B4672A backhoe. Not exactly a BH90 and L series. But I handled the interference by having my top cylinder on a quick disconnect line so I can remove the top cylinder when the backhoe is on. The side cylinder stays mounted all the time.
   / BH90 w/ T&T
Grass,
Thanks. I think I have my answer....which is it won't be as much of a problem as I thought.
Jim
   / BH90 w/ T&T #8
Any Time /forums/images/graemlins/smile.gif
RIDGID POWER DRIVE/HAND HELD THREADER (A53843)
RIDGID POWER...
2005 JLG Skytrack 8042 (A47477)
2005 JLG Skytrack...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
