caspar3259
Bronze Member
I'm looking for someone who has a technical manual / repair manual on the Kubota BH77 backhoe.
I suspect my dipperstick cylinder's relief valve is set too low, so I would like to find out what PSI it should be as well as what the PSI should be for the other cylinders. Is this also what the sometimes call the "breakout force"??
Here's the problem I observe: if I extend the backhoe and set the bucket on the ground, then try lowering the boom, the dipperstick cylinder will compress. Likewise if I curl the bucket against something difficult to move, the dipperstick cylinder compresses.
It sure seems like the dipperstick cylinder is giving way too easily and not allowing the other cylinders to exert full digging force.
thanks,
-Jeff
thanks,
-Jeff
