====================How does the BH attach on the sub frame for the CK20s? How long does it take once you have done it?
KC
I think the key here is alignment. Assuming you are right on target as you back up the tractor to engage the frame then it's simply a matter of dropping two pins to secure tractor and subframe and then attaching the two hydraulic hoses.
It could be accomplished in ten minutes if you have stored the subframe backhoe at proper height and are alligned properly. I take my time and especially watch the filters to make sure nothing gets knocked around. let' call it a half hour job assuming additional passes have to be taken at allignment. ymmv
rimshot
