BH lights
   / BH lights #1
billfires
Southeastern Mass
New Holland 1920
Does anyone dig with their BH at night? If so what do you use for lights? I ended up digging a grave Friday that was done mostly with light from a 6V lantern after the sun had set. I have a NH 1920 and was wondering if 2 lights mounted reaeward on top of the ROPS would give enough light or would I need a light mounted to the boom (maybe removeable)? Thanks for any opinions and info.
Bill C
   / BH lights #2
Bill, I have a worklight mounted on my canopy in the rear. It provides enough light for digging as long as it's not too deep. I have yet to figure out where to mount a light for grave digging. I have thought of mounting a light on the BH, maybe on the lower arm pointing at the bucket, but figure it would get damaged/torn off. I also envisioned the wiring getting damaged. We usually end up using a Coleman lantern for grave digging after dark. Nice bright light and no cords or batterys.
   / BH lights #3
I have never dug a grave, but I have done some digging after dark. The best place to have a light is at the top of the boom. I put mine where the SMV sign mounts. It works really well there. The only problem is when you are using a real thin bucket and are digging deep. If you using anything larger that 10”, you should be alright. BTW, my canopy lights didn’t work worth a flip for digging with the hoe. The glare was awful.
   / BH lights #4
BILL i had too dig one last week at night i used the tripod halogen work lights you have a cord but with the tripod it directs light into the hole but I would love to have some mounted on backhoe. Let us know what you do
EDT
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
Safety Basket (A50121)
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
Champion C80 B Motor Grader (A50322)
Champion C80 B...
40' CONTAINER (A51244)
