BH install, PTO pump internal oil sump?
   / BH install, PTO pump internal oil sump? #1
Paddy
Veteran Member
Bloomington, IN
Kubota, G5200, KAMA 454
I have taken on the project to install a Ford 3PH BH, 753. I'm in the process of welding up a subframe and fixing many of the problems. The old girl is pretty beat and I may spend more time and $$ than it's worth! It came with a new-ish Prince 21 gal/min PTO pump and I have bought a new set of valves that have 20 gal/min capacity. It also has a 10 gal tank and was run independant of the tractor's hydro system.
Can I use my tractors hydro system's oil sump and skip the external tank? The tractor is a China made KAMA 454, 45 hp, with a FEL. The pump on the tractor is a bit slow so I woukd like to use the external PTO pump but "share" the hydro fluid. Why have two tanks?
Patrick T,
   / BH install, PTO pump internal oil sump? #2
Yeah, you could do that, Paddy. You would need a suction inlet to your
filter that was below the level of the fluid in the tractor's reservoir. The
return is much easier as you can even use a adapter to your tractor's
fluid fill port.
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2020 Ram ProMaster 1500 Van, VIN # 3C6TRVAG5LE100108 (A51572)
2020 Ram ProMaster...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
