BH 77 on ROPS 2650
   / BH 77 on ROPS 2650 #1
CJHL
erie pennsylvania
Kubota B2650, John Deere 5103
I am getting ready to order a bh77 for my 2650. I know you loose the suspension seat when you put the swivel assembly on and would really like to keep that. I have seen a few videos where the cab model mount is used on the rops model and you use the cab spacers that move the whole backhoe away from the rear of the tractor and you can keep the suspension seat and use the fixed seat that comes with the cab model mount for when you are digging.
Now my thought here is that maybe i could mount the backhoe without the cab spacers and still be able to use both seats. It would be the way it looks like the bh77 is mounted to an L series tractor. There are both seats in place still, but you have to flip the drivers seat forward to flip the backhoe seat down before use.
There is a youtube channel called mattsneed for speed and he has the cab spacers on the rops and it works just fine. I just would like to have the hoe closer to the rear of the machine as opposed to using the spacers. In his videos it does look like it would work without the cab spacers, but I could be wrong on it. I don't know if anyone on here has tried this, but I did come across a few threads about people wishing they would have kept the suspension seat for normal use when hoe is off the tractor.
Any thoughts on this are appreciated.
Well after a bit more searching, I found a picture on the another forum of a guy with a 2650 that did exactly what I am hoping will work. I would still love to hear any other pro/cons of this setup.
   / BH 77 on ROPS 2650 #3
I just put a backhoe on my B2620 and am also going to figure something out this summer. I'm thinking I can can still mount the springs off the old base. But I was also thinking that....put the original seat base back on and make a mount for a second seat.
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
JLG 1930ES ELECTRIC SCISSOR MAN LIFT (A51246)
JLG 1930ES...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 72"...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51692)
2023 Stryker...
2004 MCI D4500 Passenger Bus, VIN # 1M8PDMPA54P056247 (A51572)
2004 MCI D4500...
JOHN DEERE 3033R LOT NUMBER 225 (A53084)
JOHN DEERE 3033R...
