BH 75 Dipper Cylinder
/ BH 75 Dipper Cylinder #1
Jw5875
NW Pa.
Kubota L3400
Considering to purchase a a BH75 for my L3400. Is there a reference to the upgrades that were made as to new cylinder Dia. or serial number range??
jw5875
/ BH 75 Dipper Cylinder #2
As far as I know, the dipper stick cylinder was changed from a 30mm dia. rod to 32mm. You would have to measure this with calipers to be sure; eyeballing it with a ruler wouldn't be close enough. Unless your eyeballs are calibrated or something ;-)
The old part number for the complete cylinder is 7K501-32010 and the new part number is 7K501-32020, but these numbers are not stamped on the cylinder. I believe these cylinders are made for Kubota by some outfit in Italy. You might find a number like DE 65/30x495 or DE 65/32x495 stamped on the cylinder if the paint hasn't filled it in. It's obvious which stamped number is for the larger 32mm rod.
/ BH 75 Dipper Cylinder #3
The cylinders look about the same. I was one of the first to experience the problem and after three broken cylinders and my video tape of it breaking, Kubota finally upgraded the cylinder. i now love it!!
2017 Bobcat T770 Compact Track Loader (A63689)
2017 Bobcat T770...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
7' Disc (A62613)
7' Disc (A62613)
2015 JOHN DEERE 644KH HYBRID LOADER (A66091)
2015 JOHN DEERE...
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
