Loader BF400G loader removal off L2550 Kubota
   / BF400G loader removal off L2550 Kubota #1
zimcocomp
West Newfield, Southern Maine
Kubota L2550 4wd, & Bolens QT 16, w/ Diy FEL
I need help figuring out how to remove the BF400G FEL from my L2550 Kubota. I have the four legs for it but what do I do?
   / BF400G loader removal off L2550 Kubota #2
I'm not familiar with your loader. Generally you would install the legs with the bucket lowered. (It may need to be slightly raised to install the legs.) There will be some kind of pin on each side of the tractor where the loader is held to the tractor bracket. Remove these. At this point you will have to (as I recall) lower the bucket slightly. This will lift the bracket away from the tractor mount. Turn off the tractor. Disconnect the hydraulic lines. Plug them as required - depends on the tractor. You should now be able to back the tractor away from the loader. Reverse the process to reinstall.
   / BF400G loader removal off L2550 Kubota #3
It is attached by the mounting hardware at rear of the front wheels and two bolts in front of the radiator. You leave it connect hydraulically until you get out from under it. Across the top in front of the driver should be the leg braces. Do not leave them on or you will take off the exhaust... :)
Disconnect the hydraulic line and connect between the two "tractor side" connection points.
2015 GMC Yukon XL SLT 4WD SUV (A50324)
2015 GMC Yukon XL...
2013 RAM 4500 (A50323)
2017 Jaguar F-Pace AWD SUV (A50324)
2017 Jaguar F-Pace...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
19200 (A50324)
19200 (A50324)
