patrick_g
Elite Member
So, in the aftermath of the Blizzard of 2009 here in Oklahoma we had a blanket of snow all over the place. I had the HD 6 ft brush hog on the 3PH as counter weight to make handling 1000 + lb round bales a less exciting activity when feeding the herd. I was cruising along at a fast walking pace when I encountered a rough feature in the terrain which was masked by the snow cover. No bale on the spike, just the brush hog on the back.
S H E B A N G !!! I hit the rough terrain and the brush hog hit the dirt. The 3PH was totally ineffective. I had to unhitch the mower to be able to continue. The 3PH would not even lift itself, empty.
Now that the grass has greened up and I don't have to supply hay to the herd I could take the tractor in for repairs. I had a few other little items to take care of but the broken 3PH was the bulk of the cost which was nearly a thousand dollars. The tractor mechanic said that usually a large push-rod is shoved through a hydraulic piston but not this time. It bent the rod (larger in diameter than my thumb) and broke one thingy in half and ruined the piston. All is fixed and I can now, disc, spray, box blade, mow, grade, mix cement and lots of other 3PH activities.
This is a cautionary tale that has taught me a lesson or three. Don't drive through snow unless you know what is underneath. Don't bounce the tractor with heavy implements raised on the 3PH.
Pat
Pat
